CAT7 ethernet cable worth it?
I’m seeking two short Ethernet cables, #1 one without grounding (Cat6) and #2 with grounding (Cat7). The #2 Cat7 cable will be used to ground a Ethernet filter to an endpoint (grounding desired). The #1 Cat6 will connect from network to the filter on the other end and grounding is not desired
#1 = Blue Jeans Cat6a… any length over 1-foot that I want. Done.
#2 = Cat7 = from whom??? The shortest I’ve found is from Audioquest at .75M. I’d go half that length or even less if someone could suggest one!
Pangea? Audioadvisor.com has half meter ones I think…
https://www.audioadvisor.com/mobile/prodinfo.asp?number=PGETPR
I emailed Audioadvisor to see if they answer about connector grounding. The info on the part is lacking!
I ordered the following:
(Already have NAS on LAN with 6,800 hi-res albums)
i7 Roon Transporter (https://tinyurl.com/y5atnhsp) connecting spare port to:
Cat6a 1.5ft Blue Jeans Cable ungrounded to:
GigaFOILv4 filter (https://tinyurl.com/y6bdcrv5) to:
Cat7 .75m Audioquest Vodka cable (https://tinyurl.com/y3sw42qa) grounding to:
MSB Network Renderer v2 (https://tinyurl.com/y2mt34a3) inside:
MSB Analog DAC (https://tinyurl.com/y64ulxpj) to the amps:
https://tinyurl.com/y6mxu5zo
Also just received a pair of the Mazda 12AX7S five-star triple-mica tubes today and they appear to winners, likely bumping the Telefunken tubes out of position!
