I am running DSP volume from Roon to my Poly/Mojo2 in order to use a bluetooth volume remote. The volume balls on my Mojo2 still work, which I assume means I have 2 volumes in the signal path, one of which, the Mojo 2 has no way of being bypassed? Assuming I only want to actually change the volume on the Roon using the DSP, what would be the optimal volume level to leave my Mojo 2/Poly at for sonics? Would having the Mojo2/Poly volume at 100% have any sonic difference over say 80%?
In general, it’s possible for the internal gain of the DAC to make a difference in SQ. Some DACs tend to clip full-scale signals at 100% gain, which is visible in measurements. I guess the best bet would be to set it to 80-90%, but I don’t have the Mojo, so it’s possible it works best at 100%. Also, since you’d be using DSP volume, you might as well use headroom adjustment, which is a more robust way to prevent clipping.
Unity gain, eg. 100% would be ideal, but as said above, that might clip. Don’t over think it.
Thanks all for the input. I think I’m settling on azure or blue (two of my favorite colors) and calling it a day. Cheers.
