Hello. When playing through Chromecast with the parametric equalizer enabled, I experience frequent audio interruptions. This doesn’t occur when the parametric equalizer is disabled, and playback is smooth. There are also no issues when playing through Airplay, even with the parametric equalizer enabled. The same hardware and network settings are used in all cases.
Therefore, normal playback through Chromecast is only possible with the parametric equalizer disabled. Playback through Airplay is possible with or without the parametric equalizer enabled.
How can I play audio through Chromecast with the parametric equalizer enabled?
