Full form submission What’s happening? I'm having trouble with Roon ARC
What best describes your issue with ARC Can't setup connection with Roon
Whith my new Movistart router I need to configure the ruter to get access with ARC. I have Rock in NUC installed and connected via ethernet. Could you tell mme what I sahll do in the router in order to allow ARC to connect? Which the protocol to be set in the router?
connor
(Connor)
February 29, 2024, 1:18am
4
Hi @francisco_gaston ,
Based on your last correspondence concerning port forwarding, your ISP resolved the issue by changing some preset port assignments for your account.
Full form submission What’s happening? I'm having trouble with Roon ARC What best describes your issue with ARC Can't setup connection with Roon Whith my new Movistart router I need to configure the ruter to get access with ARC. I have Rock in NUC installed and connected via ethernet. Could you tell mme what I sahll do in the router in order to allow ARC to connect? Which the protocol to be set in the router?
Do you still have the same internet service provider?
What is the diagnostic message you’re seeing in Settings → ARC currently?
We’ll proceed from there.
Thanks Finally In cooperation with ohone operator They did remotly open the port for my ROCK address
Please closectgecsubject and thanks
