Team,
Can I connect my PRO iDSD directly to roon N+ using N+'s USB A to iDSD’s USB B?
Regards,
Tushar.
Team,
Regards,
Tushar.
Use USB Type A to connect a hard disk drive or a memory stick or Type B to connect a laptop or server.
Or slot in a micro SDHC card with music files for instant playback.
Enjoy soulful tunes from your CD transport and enhance your gaming or movie experience as you connect via the coaxial/digital input.
Sound has never sounded so good.
Hi,
Will the XLR & the 2.5 mm output of Pro iDSD have outputs simultaneously?
Regards,
Tushar.
Hi,
I just checked the manual and couldn’t find anything to qualify if XLR and 2.5mm outputs could be simultaneous.
However I found an in-depth review here:
https://www.soundstagesimplifi.com/index.php/equipment-reviews/124-ifi-audio-pro-idsd-streaming-dac-preamp-headphone-amplifier
The reviewer states:
“when headphones are plugged into the iFi, the output from its XLR and RCA jacks is automatically muted”.
So sorry, but no.
Regards, Tony.
Thank you so very much… It helps a lot.
