Connecting core and output device
Hello,
I am considering using Roon with a mac mini (2020 i5). I could output from the mac directly to my dac/amplifier (Peachtree), but I’ve read it’s preferable to separate the core from the output device. So I will plan to use it with my Bluesound node 2i.
The doc says: “plan for an ethernet cable between your Core and Output components.” This is probably a silly question, but should I take this to mean simply that both the mac and the node 2i should be connected to the network with ethernet? Reading that sentence literally, I don’t see how I would put an ethernet cable between them, but I want to be sure I’m not missing another option.
Welcome to the community, @Sam_McNest!
Yes, you need to connect both Mac and Node2i to your home network. That means connecting each to your network router or a switch if you use one.
Thank you!
Which Peachtree?
