I recently acquired an old Cambridge Audio CD36 for very cheap which I am using as a CD transport into the DAC in my Cambridge CXNV2.
The CD36 used to have a remote control but was lost. The CXNV2 has a very nice remote with buttons for other members of the CX family too (CD player and amp).
I recently noticed that the volume buttons on the CXNV2’s remote control also affects the volume on my amp (Rega Brio) so I guess they are sharing some kind of protocol (?!).
My question is, can I do something that will allow me to control the CD36 with the CXNV2’s remote?
Thanks in advance!
Robin
mjw
2
More likely, the CXN is applying volume control at the analogue output. In other words, your CXN is working as a digital preamplifier.
Thanks for you reply Martin. It’s definitely not that because the CXN is set to fixed output level and, more importantly, I can see the volume wheel turn on the Rega amp. In fact the remote will even control the volume on the amp when the CXN is turned off!
mjw
4
I guess the real test is to turn the CXN off and confirm that the remote controls the Rega.
