Hello there,
when I open up Roon on a MacBook and the endpoint that has been selected last is not available, I will need to select an endpoint in the MacBook. Could the behaviour be changed so that: when the last used endpoint is not available when starting a client, default the endpoint to the integrated device (or any other available for that matter).
At least an option to force such behaviour would be welcomed.
