is there really any difference in sound quality wise between ‘ENHANCED’(blue star) and ‘LOSSLESS’(gray star)?
and how do i change from enhanced to just lossless
You likely have upsampling enabled in DSP settings for your zone. Turn those off and you should have lossless SQ.
I did and I now have Lossless-thank you very much (sounds the same which means to my ears pristine)
bobbmd
