I’m having a problem with two of my ropieee displays. I think this is a new issue, but I’ve been running ropieee for quite a while and it all blurs together.
Reproducing the behaviour:
Touch screen volume icon
Press volume down (or up) which correctly changes volume by 1 increment
Subsequent presses of the same “button” do nothing
A workaround is to use the volume slider (which works fine) but I generally find it difficult to be accurate with that and always go too loud or too quiet. It’s happening with the official screen (and another one).
@James_Fitzell I have tested it on my RPI-screen, and I can tell you that the same behavior happens here. I can only once increase one step when clicking the loudspeakers at the extremes of the volume slider. I think that @spockfish will have to check this inconvenience. I am sure that Harry will be able to fix it in a next release.
