Some more measurements now that I’ve settled on a final (for now) set of filters.
This is the raw response after driver linearisation:
On reflection, the midrange amplifier could be dropped to medium gain; this would reduce the overall system gain reduction and keep a bit more voltage output on the Motu.
Interestingly, the “Target” curve is Uli Brüggemann’s target curve which if the mid range gain was reduced by ~6 dB would closely approximate the natural response curve of the speaker in the room. (The drivers are linearised nearfield to a quasi-anechoic flat response). There’s much discussion about “target” curves and some who oppose them. Dr. Floyd Toole’s thinking is that they should be more appropriately considered “result” curves rather than target curves as a speaker tuned to a flat anechoic on-axis response will result in in an in-room response with a bass boost and a falling frequency response curve. All of the common target curves follow this more or less. Note that the curves extend to 24 kHz, so the taper in the HF response in the Brüggemann curve isn’t as pronounced as it first appears:
Frequency Response, L&R, Mono and target curve (a 16 Hz subsonic filter was added at the filter generation stage):
Overall, I’m fairly happy, pretty much ±2 dB. The dip in the left at ~100 Hz is due to room asymmetry and attempts to fix it caused more problems than they solved. In the mono, it’s less noticeable. Bass is generally mono below about 200 Hz anyway.
Step response, this is where zero delay plane (ZDP) time alignment and phase linearisation really shines. All drivers are precisely aligned:
There’s a small amount of pre-ringing in the left channel due to the inter-channel phase alignment adjustment, however the worst of it is within 10 ms of the step, so it’s well within the psychoacoustic masking window (20 ms). It’s not audible on any tracks I’ve tested to try to bring it out.
ICCC, or IACC (Interaural Coherence Coefficient) as it’s also known is fairly respectable. The ICCC10 is just over 70%. With a more symmetric room layout (my listening room is the lounge), that would significantly improve.
My room’s RT60 is pretty good, due to the room treatments applied, so further treatment might help the ICCC, but conversely could make the room sound too dead:
Overall, the conversion to a fully active setup with Acourate filters has been a great success. Bass is tighter, the soundstage is much larger and extends left and right beyond the speakers. Depth perception is much greater, both in front of and behind the speakers and the overall sense of realism is just exceptional. I’ve put in more sofa hours in the last few days than I have in the past few months. I just want to sit and listen to music all day every day.
Linear phase speakers are pretty rare - the only commercially available system I’m aware of at present is from Lundahl Sound Systems. I use Karl’s SV2361 volume control before my power amps.
Here’s a link to a paper written on linear phase:
