Does Roon's MUSE work with Sonos?
When I use Roon to play on the Sonos Amp, even when MUSE is enabled (Convolution) the signal path shows the data going directly from Qobuz (my source) to Sonos Amp.
Does this mean that no MUSE settings are applied when playing to a Sonos device?
In other words, when using Sonos, does Roon just work as a fancy interface (GUI) to find the music?
Please post a screenshot of what you see …
Thanks for the reply. I figured it out. Initially I was streaming via Airplay without realizing it. Once I switched to WiFi, the convolution settings were applied. In summary: Roon’s Muse does work with Sonos. Thanks!!
It probably works via Airplay too - but Roon will see that as a different endpoint; you would need to configure Muse for that specific endpoint as well…
When you say “Switched to WiFi” do you mean you swithed to Sonos Net? I just came to Roon and starting to figure things out.
