Hi there,
I’m observing some dropouts with MQA tracks with this setup. I am running a Raspberry Pi 3 Model B Rev 1.2, ROCK Version 1.7 (build 511) stable. This is the log #### fbf7e2b76019616d.
RoPieee is running over WiFi (no option to do otherwise), ROCK is connected via a wired connection to the router, and didn’t observe the same with non-MQA tracks, so I wouldn’t be surprised if it is a network issue, but figured I’d check. It is only sporadic and I did try to increase the buffer to the 500ms max in the Roon controller.
I should add that I use a Google WiFi mesh WiFi system.
Thanks for any help!
