Hi
RoPieeeXL 2022.11.2 (0664)
Raspberry Pi 4 Model B Rev 1.5
HIFIBERRY DIGI2 PRO ver 2.2 (newest)
Topping MX5
Connection SPDIF (optical)
I use the Dynamic Audio Power Mgt: ON option because my Topping MX5 amplifiers go into a standby state when activity on the SPDIF link is turned off.
Unfortunately, I can not describe exactly when, but very often my optical connection is not turned off and the amplifier continuously remains on (Mx5 detects activity on the optical link and turns off, I have not had the described problem with other devices - Belkin AirPlay). I have 3 identical configurations and the described problem occurs on each of them. I temporarily solve this problem by turning on the Reboot Schedule (Daily) option, which always turns off the optical link.
Perhaps this post will help improve the next versions.
Regards T.
