EQ Preset for McIntosh MHP1000 (Tesla driver, DT1770 Pro based) Tested with Roon + HQPlayer + Mytek Brooklyn DAC
Hey everyone,
after a lot of listening and cross-checking measurements, I’d like to share a recommended parametric EQ (PEQ) setup in Roon for the McIntosh MHP1000 headphones. These are high-end closed-back cans based on the Beyerdynamic Tesla driver, very similar to the DT1770 Pro – and as such, they share a similar tonal profile.
:mag_right: Summary of frequency characteristics:
  • Strong midbass hump (~150 Hz): Creates warmth but can sound bloated or overpowering, especially in long sessions.
  • Recessed low mids (~200 Hz): Adds to the “V-shaped” sound profile.
  • Slight dip in presence region (~2–5 kHz): Leads to softer vocals and a less energetic midrange.
  • Treble peaks (~6 kHz + ~8.5 kHz): Adds sparkle but can be sibilant or fatiguing. The 8.5 kHz peak especially adds grain to cymbals/sibilants.
:headphones: Goal of EQ: Neutralize the tonal balance closer to Harman-style tuning without losing dynamics or excitement.
:white_check_mark: Recommended PEQ filters in Roon DSP:
Band Type Freq (Hz) Q Gain (dB) Purpose
1 Peak 150 1.4 –6.0 Tames midbass bloat
2 Peak 3000 1.4 +3.0 Restores vocal presence/detail
3 Peak 6000 3.0 –2.0 Smooths upper mids glare
4 Peak 8500 4.0 –8.0 Controls treble peak/sibilance
:brain: Don’t forget to:
  • Enable Headroom Management in Roon and set Preamp to –5 dB to prevent clipping.
  • Use 64-bit float output to HQPlayer if that’s your backend.
  • Double check Roon’s signal path – EQ should be applied before HQP takes over.
:bulb: Context & source:
These filters are based on measurements from DIY-Audio-Heaven and Sonarworks for the DT1770 Pro, which shares identical Tesla driver tuning. I tested these settings with Mytek Brooklyn DAC → HQPlayer (DSD256) → MHP1000. The result? Much more balanced and natural tone. Bass is tight, vocals cut through, and treble is smooth yet detailed.
:level_slider: Feel free to tweak from here:
  • Want more punch? Reduce the bass cut a bit.
  • Still find treble hot? Add a narrow notch around 9 kHz.
Let me know how this works for your setup – and if you’ve created your own tuning for MHP1000 or DT1770, share it below!
Tested in chain: Roon ROCK → HQPlayer Embedded (on Zorin OS) → Mytek Brooklyn DAC → McIntosh MHP1000
Roon Software Discussion #headphones #dsp #eq #mhp1000 #hqplayer #mytek #tesla #beyerdynamic #dt1770pro #parametriceq
