I sorted my library in itunes and noticed some really low bit rate stuff in there. Is it possible to filter out low bit rate music in Roon? I’m trying to replace some of this music with higher bit rate or re-ripping cd’s where I have them. Until then, I don’t want some of them to play.
Select view by albums, then focus, then format then choose the resolution.
Russ
Russ - will that limit playback to a minimum bitrate? I’m remote, out of the house next couple of days so can’t try it until the weekend.
It will let you select the bitrate and display them or exclude them from the display, is that what you want?
Russ
I want to exclude tracks that are below a certain bitrate from playing.
Yes you can do this, get back in touch when you are doing this and I will help if you want me to?
Russ
Is filter by bit rate gone in 1.8? I can’t find it
