Since the last update I have been having issues with the volume level DSP in muse. If it is enabled it causes incorrect playback depending on the format of the audio.
44.1 stuttering
High Res is sped up or slowed down
Dsd is sped up or slowed down
First time I have ever encountered this.
Google pixel 8 pro
Ibasso DC elite usb DAC.
Hi @Billy_k !
Thanks for posting!
A couple of questions to clarify:
- What are the settings for playback via WiFi and mobile network? (Automatically pick best quality\Original format\CD Quality)
- Have you tried to change the settings and start playback? How is ARC behaving in such conditions?
- Do you use the USB Driver (Beta)?
Thank you,
Andrew
- Automatically pick best quality
- Playback returns to normal with Volume Level switched off
- Yes I use the beta USB drivers, but strangely it also happens when audio is going through the android mixer
Hi, @Billy_k, could you please install the latest EA build and see if this issue is still reproducible for you?
ā
Ivan
Hi Ivan
All seems to be working fine now thank you.
