I’m currently using roon with a preamp so I prefer to use ‘fixed volume’
When I set the volume to ‘fixed volume’ it sets it to the volume percentage currently selected. What is the optimum percentage I should select before fixing the volume?
The manufacturer of the device feeding your pre-amp should be able to tell you how to set it. When I owned a Meridian 808v6 it was 87. My current dCS gear shows 0.
With some devices you just select fixed or variable.
Thanks for your help. I think I’ve found a fix by setting Roon to ‘DPS volume’ it sets the volume to 0db and as long as I keep it set to that I get full quality. P
Surprised that DSP Volume was helpful. I was going to suggest “Fixed Volume” for "Volume Control and (under Advanced in Device Setup), enable “Force Max Volume At Playback Start”.
