I am downsizing, and don’t actually need both my CXAs: I only need one.
I am selling the one that has been stored for the past six months or so. Fewer than 50 hours of playback. It is in excellent condition, 9.9+cosmetics (I can’t find any scratches, abrasions, etc.)/10.0 electronics. Still has factory plastic protection film on window.
CXA61 offers multiple digital and analog inputs, outputs for two sets of speakers, a sub output, a fine DAC, etc, etc. Plays your digital files up to 24/384 and DSD256, Amazon et al sells it new for $1099, and you can risk a refurb for $870 or so/ I will sell you mine for $550, shipped in the US using factory cardboard and packing. PayPal, please. Power Cord, Remote, thumb drive with digital owner’s manual.
The internet is packed with glowing reviews of how well this device plays. Here are some specifics:
POWER OUTPUT: 60W RMS per channel into 8 Ohms, 90W RMS into 4 Ohm
DAC: ESS Sabre ES9010K2M
FREQUENCY RESPONSE: <5Hz– 60kHz +/-1dB
ANALOG AUDIO INPUTS: 4 x RCA, 1 x 3.5mm MP3 input (front panel
DIGITAL AUDIO INPUTS: 1 x S/PDIF coaxial, 2 x TOSLINK optical, 1 x USB audio, Bluetooth (integrated)
COMPATIBILITY: USB: audio profile 1.0/2.0 (default 2.0), up to 24-bit 384kHz PCM, up to DSD256 or DoP256: TOSLINK optical: 16/24bit 32-96kHz PCM only, S/PDIF coaxial: 16/24bit 32-192kHz PCM only, Bluetooth: 4.2 A2DP/AVRCP supporting up to aptX HD (24bit 48kHz)
BLUETOOTH: APTX HD Receiver built-in
ROON TESTED
OUTPUTS: Speakers A+B, 3.5mm Headphone, Preamp Output, Subwoofer Output
REMOTE CONTROL
MAX POWER CONSUMPTION: 600W
STANDBY POWER CONSUMPTION: <0.5W
DIMENSIONS (H X W X D): 115 x 430 x 341mm (4.5 x 16.9 x 13.4”)
WEIGHT: 8.3kg (18.3lbs)
