FS: Teddy Pardo TeddyNuc Power Supply
TeddyNUC: Power Supply for Intel NUC (Roon Rock, Roon Nucleus and NucleusPlus etc.)
*$250 Shipping for lower 48 is included for free. PP only.
The TeddyNUC is an ultra low noise power supply that can be used to replace the switching power adaptor that comes with media-PCs such as Intel NUC, Roon Nucleus, Sonic Transporter etc. The TeddyNUC provides significant improvement in sound quality, resulting from a reduced noise-floor.
The design is based on the experience gained with the TeddyCap family of power supplies for Naim Audio equipment and uses the same technology.
Specifications are 19V DC, with up to 3.5A output current.
Works with All generations of Intel NUC , with CPU TDP up to 65W, this means i3/i5/i7 CPUs., Roon Nucleus, Nucleus+ , all versions, Innuos Zen Mini - all versions****,**** Asrock Beebox (S version only with i3/5), Small Green Computer Sonictransporter - all versions with CPU TDP up to 65W. Please note: Sonictransporter i9 is not supported.
How old/date. Do you have all original packaging, manuals. Thanks
Honestly it is boxed up in its original packaging.
Not to sound too glib, but as far as I can remember there was no manual- you plug it in to the Nucleus (or whatever other components use that voltage), plug it into the wall socket and turn it on.
It’s , I guess, 5 yo., but i don’t have the invoice.
I will send you photo’s if I have an email from you. I can’t load photos on the ads here or the response.
Thanks,
Tom
I see on the original shipping label from Teddy Pardo that it was mailed from Isreal on 10/4/2019, so 5 years old was a good guess.
Tom
Guys , publicizing your email addresses is a bit dodgy , maybe use the forum PM function
