I’m still having issues such as the display not updating, while the play controls are still operational. I also noticed today that in the Settings/Extensions screen there’s a number in brackets after the Status: Running message. What does this mean?
That’s just an indication on how long the extension is running.
If you run into an issue, can you send me feedback?
Will do. I’m currently hunting down another issue at the moment. Once that’s nailed, I’ll be able to get back to this one. Thanks.
OK, other issue sorted (or at least, a workaround has been found). Back to the non-updating display issue. It’s still happening. Feedback: 92ade85269129955. Thanks.
