Is it accurate that Sonos cannot be grouped with an audio device such as Auralic Aries G2?
Thank you
Thank you
Only devices that support the same protocols can be grouped:
You can’t group the Auralic into a Sonos group because it does not support the Sonos protocol, and you can’t group them with Roon Ready RAAT because the Sonos does not support that. However, the G2.2 does support AirPlay 2, so if the Sonos does as well (I don’t know for sure) then you could group them this way.
Thank you very much
