Hi there!
I want to build an amplifier with a Raspberry Pi so I was thinking in buy the Allo Kali + Allo Piano 2.1 + Allo Volt but I’m doubting with the PSU. I would like to put everything in the same enclosure so I was thinking on the Allo Dual LLC PSU, but in my opinion, it will make the amplifier bigger than I had planned, so I was thinking on replace it with a Mean Well PSU + the Allo Capacitance Multiplier.
I don’t have knowledge about power so that’s why I’m here asking for help. Do you think the Mean Well G3 Series is good for my project? If so… Which PSU will be better between the RD-65, RID-65, RD-85 and RID-85? Do you recommend another PSU instead?
I’m going to use this amplifier with a pair of Pioneer HPM-50 3-way and 2x40W - 8Ω on a living room/kitchen of 20 square meters.
Thanks in advance,
Cesar
