I am a user of Roon products, I have the following questions when I am using Roon, and please provide me some solutions or suggestions
I assembled a Fanless mini pc by myself,and the hardware configuration is as follows: Asus H410T2/esm motherboard,i3 10010T intel CPu, samsung 3g*2 memory, anid samnsing evo970 plus ssd.Roon Rockis strictly installed acording to the oficial guide step by step. lt is curently the latest version of 1.8. But the question is,
- Rock can be nomally discovered by the device, but there seems to be a problem with my network adapter driver. My home is a 1G optical iber network,and the router is asus’s axsbu use
cat7 cable, H410T2/cSM’s onboard network adapter is a 1000m network adapter, but the router can only recognize the connection of the roon troek host which is too.m only
2.After Roon rock is just instaled, it prompts Mising odecs, Follow the instructions on the oficial websit,I download the decoded fite and solve the problem, but i the rock resnuts sahet
shutting down, “missing Codecs” appear again, this happens 4 times already
For above issues, please provide a solution otherwise I get a bad experience when using roon Rock.
Thank you and best regards
