I think so - I haven’t changed anything since it was working a couple of days ago. Would it look like this?
Yes. Click View and remove if in there, then authorize the newly discovered one.
In Roon —> Settings —> Audio, would you verify that the audio zone hasn’t for some reason been renamed slightly? Copy and paste is sometimes helpful here to ensure identical spelling.
You need the same names for the zone and the display setting
The naming was the problem. When I had to reinstall Roon I lost the name for the zone. Thank you all for your help.
