Help! RoPieeeXXL broke for me, and I can't get it to work at all anymore
Hi there, the user manual told me to go to this forum and ask for help, I think? Anyway, below is the string of characters that the software wanted me to put on the Internet to help troubleshoot I think? The whole thing is pretty confusing at this point, this software and streaming to a Raspberry Pie 4B and a USB DAC worked pretty well for like years, and suddenly it’s broken.
Any help is welcome!
0e6e08f67e4361c5
While we wait for Harry to look at your feedback (I am assuming that the string above is from feedback, correct?) some things to check.
Might try just rebooting everything (network, RPi, roon server machine, etc)?
Do you see the RPi in Roon settings/audio or Roon Bridge in Roon Settings/About?
If so, for in settings audio is the zone enabled?
If not in settings audio, is the DAC turned on? Unplug and replug the USB and reboot the DAC?
Also, check the webUI for RoPieee to make sure Audio USB is still turned on.
Can you provide more information? What is exactly ‘broken’?
Hey. Thanks for the reply. What happened is that I attempted to reconfigure the Raspberry Pie to receive streamed music using its own WiFi card, instead of using the ethernet connection from the old Airport Express (Gen 1), as I had done since initially setting it up years ago. But it didn’t work, and neither the Mac OS Spotify desktop app, the Spotify iOS app, nor Airplay from Mac OS (“Ropieeexxl” under the speaker icon in the top right of the desktop) work anymore. I tried multiple times to change various settings, referring to the Ropieeexxl setup guide for clues, etc. That’s my sad story, but I kinda gave up and ordered a simple streamer from Amazon and plan to ditch the Pie, which is kinda overkill for my purposes I guess.
Reflash the micro SD card.
I have the same problem - my Ropieee “disappears” in the middle of playback via Roon. I have two Raspberry pi4s with the same problem, I presume the problem started after some recent updates of the Ropieee (mine is set to auto update). Reflashing was of little help, the only way I could use my Ropieee devices is to connect them via Ethernet. I am yet to try to an alternate Wifi adapter to address the issue. My wifi network has both 5 & 2.4 Ghz, which probably may be the problem (though this was never an issue previously for a few years!). My temporary solution is to use the Ethernet connection for now.
