Does your network have any VPNs, proxy servers, or enterprise-grade security?
No
Apple HomePod (WiFi)
Description of Issue -
What is the exact port forwarding error message you see in the Roon Settings → ARC tab?
I just bought the Nucleus and set it up. It’s software is up-to-date. My music library is on a Synology NAS. Both connected by ethernet to a Netgear switch.
First of all, as far is i know IPv6 isn’t supported by Roon Arc yet ( i’m no employee of Roon, just a fellow community member) so i would turn that of.
Is the Technicolor a modem/router combination? Is the Google Nest WiFi also a router? If so, i would suggest you set the Technicolor in bridge mode.
I turned off IPv6 in the Google Nest WiFi. I think that is just on by default. It didn’t have an effect when I turned it off.
The Technicolor is the cable modem supplied by my ISP (Breezeline). It is one of those WiFi/Router combo’s they send out. It was supposed to be in bridge mode already as I use the Google Nest WiFi as the router for the mesh network.
I will call Breezeline to double-check this is still in place.
Hmmm, i’m running out of options. I do have one which we could try. In the Roon app under settings → Roon Arc could you change the port number to ie. 44135. After you changed it in the Roon App, change your port forwarding rule to the new port number.
On the WAN or Internet side / interface of the Google Nest Wifi, the IP of the Nest should match the 69 addresses reported in the Roon error. If not then there is a second NAT or your technicolor is not actually in Bridge mode.
