I’m not able to get Tidal MQA to my ifi ZEN DAC and get that purple light that I’m looking for with Roon. If I just use Tidal without Roon, it works fine. Pretty sure I’m doing something wrong in the Roon settings. I’m not very tech saavy, so some help would be great. I’m running a MAC with OS Catalina 10.15.1 connected to my ifi ZEN.
I suspect you haven’t setup the DAC correctly. A screenshot of your audio device settings would be useful. Specifically, what are MQA Capabilities settings in Device Setup? This should be set to Decoder and Renderer.
The last entry is the iFi DAC; name this and go into settings and make sure decoder and renderer are set for MQA and give this a go. Please post a screenshot of the new signal path.
Click on the gears next to the Zone name. Then look for MQA Capabilities in Device Settings. This needs to be set to decoder and renderer.
Once you’ve confirmed/ changed this, save and exit and then change the zone so you are playing to the iFi. See what happens and post a screenshot of the Signal Path.
Martin, I’m not near my iMac so can’t check my settings but it looks like, under system preferences, The Mac sound output needs to be set to the ifi (currently set at system output).
