There are pictures and a description right there in the App Store. Also see here:
Otherwise, simply google for “amphetamine app” and you will find articles with description
No good.
What else can I do to configure and run Amphetamine. Symptom is nothing happens, like the app is not started. Thoughts?
Dan
It doesn’t appear in your menubar, as per my previous screen grab? The reason I ask is in case you’re expecting some sort of window to open, which won’t happen.
I got the app to run. It now appears in menu bar. Shouldn’t Roon have keeping the app awake a basic function? To me it should be.
Good news that you have got amphetamine to run. On your second point, I’m not sure in my use scenario that I would want anything other than manual intervention, but I guess that’s the perennial difficulty, we all would like variations.
Roon will keep your system awake while it’s playing music, but when it’s idle it allows the system to sleep unless you have it set up to not allow sleep, as discussed above.
