Roon 1.7 Build No. 667
Innuos Zenith mk 3
USB to Acousticplan Digimaster DAC
Dear All. Just using Roon for considerable time and learned about the added value of the DSP engine recently. For a beginner, it is very “difficult” to understand all the features offered.
While it is intuitive to understand what the effects of the parametric EQ are, it is really challenging for me how to use the procedural EQ filter. What could be done using that feature to better adapt the system? In addition, are you using the Speaker Setup filter?
Thx for sharing your thoughts!
