HQPE often unavailable in ROON's Audio Zone
Hello
I have a problem when starting Ronn server/Hqplayer on my Pc host, the HQplayer is not found.
I have an AMD Ryzen host PC with Gentooplayer/Roonserveur/Hqplayer Embeded connected by ethernet via a Jcat Net card XE network card.
the Target PC is running AMD Ryzen with Gentooplayer and Diretta, also connected via ethernet using a Jcat Net card XE.
the stream is sent via a USB link on the Jcat XE card to the Holo Spring 3 level 2 DAC.
when I launch Roon server/Hqpalyer Embedded, it doesn’t find the HQplayer in the roon audio zone
I have to reboot my network box for it to find it???
thank you for your feedback
Jean-Luc
Roon doesn’t support finding HQPlayer instances, so you need to manually configure the HQPlayer IP address in Roon.
Hello
this is what i did i put the ip address of the host pc in the zone and add, only when i turn it off and on, it works 1 time on it’s very weird.
Does HQPlayer work standalone without issues? I would recommend though to use HQPlayer NAA instead of Diretta to avoid issues.
and how do you configure it?
is it in Gentooplayer’s options?
I put you the 2 decrans cover of Gentooplayer and HQPE to know if it is indeed the NAA point of Hqplayer?
I’ve never used GentooPlayer, but I guess that’s the one you need to have enabled at the endpoint.
