Received the SOTM 200 (Used price £240).
Equipment and a bit of history.
PC: Lenovo P3, Core i7 14700T, 32Gb ram, Windows 10 IoT Enterprise LTSC running essential processes only. Roon + HQPlayer. Music is on external USB SSD.
Headphones: Susvara with original balanced cable.
Head Amp: Woo Audio WA22 with We422a/ECC32/TS5998. I have lots of other tubes but these are my current favourites.
Pre Amp: Ifi Ican Pro Signature. By itself the WA22 doesn’t quite have enough gain for the Susvara
Dac: Lampizator L4G5 Dual Mono with chipless DSD512 engine
Streamer: SOTM 200 Ultra SE
Long time HQPlayer Desktop user (8 years)
Discovered Diretta about 4 months ago on the Roon Forum when SOTM began beta testing.
Prior to setting up Diretta my network was fibre to Etheregen-SOTM200-Dac.
Installed the Diretta/SOTM ASIO driver on the PC and configured the 200 Ultra as a target. Installed a USB Ethernet dongle on the PC and connected this via a crossover cable to the SOTM target.
I was very impressed with the presentation of the sound. I thought it more natural and even handed (I don’t really know how to describe it).
I spent a lot of time going through the HQPlayer modulators and filters, finally deciding on ASDM5EC-Fast512+fs, Poly-Sinc-Ext2-Short. I considered the Ext2 a little sharp in the higher frequencies but enjoyed the overall clarity.
I also very much liked Poly-Sinc-Gauss-Short for it’s more balanced/relaxed presentation but it didn’t quite have that bite to vocals compared to Ext2-Short.
Diretta Host & Target installation
Downloaded the V6.2 firmware and flashed two micro sd cards.
Followed the setup procedure as documented by SOTM and Andrew. I ensured all settings (CPU and Latency) on the SOTM devices were at default.
I initially experienced problems with the Host not seeing the Target.
This issue was resolved by ensuring the Host was powered up first and given time to display the Eunhasu web GUI before powering on the Target.
Initial impressions (headphones) was very positive. I definitely thought I noticed an improvement in clarity. In fact I found the Ext2 filter slightly to sharp. Substituting the Ext2 with the Gauss filter is now perfect to my ears. I now have that balanced/relaxed presentation and don’t feel I’m missing anything.
It’s early days and I’ve got a lot of listening to do but I’m absolutely delighted with how my system is sounding.
