Is there an install guide anywhere? I’ve download from images → naa-500-raspberrypi4-holored.7z and the asc, unzipped them and installed just those files on to a micro SD and installed the card but the Holo Red isn’t showing anywhere.
You just need to flash the 7z image … if you flash the 7z first and then the asc the latter will override the former
… and use Balena Etcher or Rufus to flash the image on the microSD card
Thanks - that did the trick.
