Yeah, they are expensive, but great quality…I am a bit OC and I like all of my wire hidden so this solution fit my vision. I got the wall mount and the case. It’s great that you can use PoE to charge the entire system as well. If you find another solution that is similar, but cheaper definitely post it. I would love more options.
