As titled
I watch videos on chrome and would like to route the sound from chrome to play on Roon by using better post-processing or sampling than what windows does. Is there a way to do it?
Not within Roon itself.
The 3rd party Entrypoint extension does allow you to achieve what you want, but in requires additional software, possibly hardware to run it on and a degree of technical skill and time to set it up.
The way it works is by making the external audio source - for example AirPlay from a laptop - appear as a radio station inside Roon, so it’s not the most seamless / elegant of solutions, but it’s there if you want to try it.
There are a couple of existing ‘feature requests’ for this kind of functionality to built natively into Roon, you might want to add your voice / vote to those.
