Hello, got an issue. Using an usbridge Sig link to my moon 340I w/ DAC. The DAC is not seeing the usbridge (no sample rate seen which could mean no audio output to me). As a consequence Roon is not seeing it as an endpoint also. Can connect to the ropieee web interface, can see it as a bridge, can see the moon on the usb output into the web interface (audio section). Just not seeing it in the Audio section of ROON. Use to work perfectly last week not change done this then.
Could you please help me. log sent1c3d6610f17b7784
Thanks a lot. Just to give you feedback if it can help and because your answer help me focus on the Roon server. I am using my Macbook air as a server, try to remove and reinstall the app → Not working so after looking at some other post went to the library on my Mac remove all the Roon%f files + raat. Reinstall everything and found my moon back into the audio setting. Don’t know where the issue is coming from at first but it works now. This and regards,
Julien
