Issue with NAT-PMP and UPnP Autoconfiguration Settings (ref#644E6W)
Full form submission
Network Setup
I use a single personal router not provided by my ISP
ARC Status
ARC is *Not Ready*
Roon Error Code
“natpmp_autoconfig”: {“status”:“NotFound”}, “upnp_autoconfig”: {“status”:“NotFound”} }
Have you successfully located and enabled the UPnP or NAT-PMP settings in your router's web UI?
I've turned UPnP/ NAT-PMP on and ARC won't connect
Select the Diagnostic Keyword or Text String
Something else
“Actual_external_ip” : “24.aaa.bbb.ddd” , “actual_external_ipv6” : “null” , “router_external_ip” : “null”
Natpmp_autoconfig “not found”
I’ve got my server set with a static IP and UPnP enabled on my router - also set a port forward.
I’m out of ideas.
Upnp_autoconfig “not found”
Turned off port forward, UPnP on, no change.
ISP is Spectrum
I own my own equipment
Modem is a Netgear
Router is a TP-Link Deco mesh system
Full error text:
“ipv4_connectivity”: {“status”:“NetworkError”,“status_code”:504,“error”:“error: Error: ETIMEDOUT, response code: undefined, body: undefined connected? undefined”},
“external_ip”: {“actual_external_ip”:“24.aaa.bbb.ccc”,“actual_external_ipv6”:“null”,“router_external_ip”:“24.aaa.bbb.ccc”},
“upnp_autoconfig”: {“server_ip”:“192.168.68.1”,“found_upnp”:true}
It’s just a modem.
Also posted full error text.
Routing duties are handled by the TP-Link Deco Mesh
Below is the error after setting port forward, UPnP off:
“external_ip”: {“actual_external_ip”:“24.aaa.bbb.ccc”,“actual_external_ipv6”:“null”,“router_external_ip”:“null”},
I believe it uses UPnP or NATPMP
Fixed it - it was the built in Windows firewall
