This really is not an issue, but i was curious whether anyone else has experienced this.
I am running DietPi (147) on a Raspberry Pi 2B and on a NanoPi Neo 512Mb. When upsampling to either 706/768Khz or DSD128/256 i get short dropouts, say every 45seconds, mostly towards the end of the song playing.
They are connected over ethernet and both of them are connected via USB to my Chord Mojo.
At DSD256 and PCM over 700khz i also have experienced one or both channels losing sync and instead playing just pink noise into my head phones or speakers.
I cannot recreate this when feeding my Mojo from a headless MacMini (2011). I dont have any other DAC that accepts these resolutions to compare the Mojo with though.
And while im at it, i cant seem to update my dietpi install over SSH, it stops at screen saying βplease backup your systemβ and when trying to do so it gets stuck when backing up some irrelevant turkish root certificateβ¦
Likely @Dan_Knight can help you with your upgrade woes β though I wouldnβt be tempted to mess with Turkish root certificatesβ¦ Perhaps the fastest / easiest way is to reflash your card with a fresh DietPi. Make sure you change your root password, just in caseβ¦
As far as the Mojo goes: I usually feed mine from a Cubox, but Iβve tried a Pi3 for a few days without any problems at PCM768 and DSD256. I guess the combination of network traffic and USB traffic at these bitrates is a bit taxing for the little bugger, but I did not have any hiccups. Are your network and core (upsampling?) are up to it?
Yes, i agree its a small task to reflash the microSD and i think iβll do that. Do you backup your DietPi system?
Edit: Sorry about this! There was no problem other than a somewhat corrupt user interface through the Reflection for Unix-app on iPad. I just managed to perform the updates on both of my active Piβs!
Concerning the high rez glitches, i would say the system can manage. I ususally get processing speeds at around 4x when upsampling to DSD256 and around 10-12x when doing 706/768Khz PCM.
And the MacMini do not show any signs of issues at the same speedsβ¦
I was eyeballing a Cubox Pro for trials as you responded. Do you run Jessie Lite on that one?
No, never. Itβs a <10 min. job to flash and configure a new card if needed (when itβs only used as RoonBridge zone).
Your upsampling numbers look fine β I agree that these should not cause any problems.
As for the Cuboxes: I have three of them around the house (i1, i2 & 4Pro). Even the i1 does not break a sweat when running RoonBridge.
I run Armbian on them. If you decide to dive in, make sure you use the Legacy release (Vanille was pretty half-baked for audio last time I tried). They changed their site a bit, offering only Ubuntu Vanilla on the first page β but I guess you need Debian_jessie_default these days, available from here: https://dl.armbian.com/cubox-i/
I touched on the Cubox installation in the old guide (instructions come after the Raspberry Pi part). You can ignore the bit about .raw files β Armbian uses .img files now that you can write to your card in the same way youβd do with DietPi.
Thx for your attention @Dan_Knight!
I discovered itβs most probably an issue caused by the Reflection app. But i will take a screenshot as soon as i can, while using Terminal on my Mac instead!
The update went fine when i (blindly) tried pressing Tab followed by Enter! So all is well, but i didnt have time to try the βdietpi-backupβ command again.
And now iβm awayβ¦
Hmmm, i must admit i had no issues with dietpi-backup when using my iMacs Terminal applicationβ¦
The issues before were clearly due to the Reflection app for iPad.
Well then another mystery solved. One still remains however!
I have two Piβs, both 2B. One is version 149 and the other 150. Both are up to date says the diet-update!
βββββββββββββββββββββββββββββββββββββββ
DietPi | 16:19 | Mon 01/05/17
V149 | RPi 2 Model B (armv7l)
IP Address | 192.168.15.136
and the other one:
DietPi | 16:18 | Mon 01/05/17
V150 | RPi 2 Model B (armv7l)
IP Address | 192.168.15.222
And, has the 384Khz-kernel-setting moved into the Just-Boom configuration?
I believe it is a quite recent image, downloaded from your main site on the 17/3 2017 at 16:23 CET.
Any suggestion how to acquire the version of the image? The file is just named βDietPi_RPi-armv6-(Jessie).7zβ
I sβpose there should be some version file somewhere on the filesystem also?
After updating my NanoPi Neo to DietPi 149 i havenβt experienced this lost sync into the Mojo again.
But the issue with short dropouts with DSD remains, and is heard mostly with DSD256, less so with DSD128 and DSD64 i have yet to try. (Similar on both Raspberry Pi 2B and NanoPi Neo)
It would be nice to read of other peoples experience with similar setup?
And a question for @Dan_Knight, is it possible to kill the blue led programatically with DietPi on the NanoPi Neo? It is so bright as to be totally useless in a dark room! Like looking into a strobe!
(blinks twice i rapid succesion every second or so, after boot up)
