KEF LS50 wireless - roon ready? [not roon ready, but supported natively]
Yep… I was thinking thinking about that device and nearly purchased it until iPeng came out w/ the update, which of course is a stopgap until we have direct Roon support. I’m sure the device is worth it (had an Audiophileo + linear power supply for my headphone rig years ago), but ultimately it’s a bit hard to justify for me for TV usage.
Okay… but there’s little justification besides a belief. I’m one of those sound science types and feel most of the claims in audiophilio not backed by some sort of science/physics are probably bunk.
I don’t doubt a good shielded ethernet – but otherwise cheap – cable is the best mode for wired connectivity, Do they talk about wireless?
Unfortunately still a hot mess. Still skips like every other time I advance a song and it disconnected already once within the first 5 minutes of usage (but it did reconnect quickly).
I play a pretty fair amount of music from You Tube on the TV plus Sometimes Pandora and Apple Music from Apple TV so it’s worth it for that given the low cost of the iFi. It’s a pretty noticeable difference. I’m using a Blue Jeans cable optical from tv to Kefs.
I’m not surprised I guess that the app still has issues. Kef needs to fire whoever they outsourced development to and hire their own if they are serious about this sort of thing.
The Sound in Sound article does not talk about WiFi but it goes into great detail on Ethernet and audio.
Just thought of something: if I buy a pair of KEFs and use ethernet to connect them to computer and play directly from Roon (once they are Roon ready), then I won’t be able to play other sounds from computer on the KEFs right? Its not like Windows will detect them as an audio endpoint.
Roon really could use a “audio endpoint” thingie so we can solve issues like this, and also get convolution and room correction for other sources. Basically Roon-Core on its own audio endpoint (similar to how Dirac done it).
Yea, the Dynaudio X14A do sound very good, and for the price to upgrade to a pair of KEF LS50 I could instead upgrade my DragonFly Rec dac and add a second decent subwoofer (and even some USB tweak). Not sure what do do :slight_smile:
Which of the 2 options below will sound best do you guys think:
  1. Dynaudio X14A + Mojo dac (or better) + AudioEngine S8 sub (8 inch) + IfI nano IUSB3 + SVS SB-2000 sub
  2. KEF LS50 + AudioEngine S8 sub (8 inch)
What you get with the Kef over the Dynaudio is:
  • no more anxiety over interconnects (eg speaker cable, etc)
  • active crossover with phase alignment
  • room DSP correction (not to be under-estimated)
  • forthcoming direct support for Roon
What you lose going with the Kefs are:
  • piece of mind. If any of the active circuitry fails then your whole music system fails
  • upgradeability (which, for me, is not a negative as it’s cured me of my audiophile upgraditis tendencies)
Really well put Rik. I agree with all especially the part about if any component fails. My replacement Kefs arrive tomorrow. At least they are sending me brand new ones.
Magnus I think about anyone will tell you the SVS sub over the Audioengine. I don’t use a sub with the Kefs myself as I don’t feel the need to for music. I tried it with an SVS PB1000 I had on hand but didn’t use it long. I’m also using the Kef’s for Home Theater but the explosions are loud enough as it is :slight_smile:
The Kef’s also cured my upgradeitis :slight_smile:
I agree as well, the KEFs don’t really need a sub, I had a 12 inch Klipsch on them for a bit but it was way overkill IMO. I also live in an apartment so the neighbors are a concern… :roll_eyes:
Yes the SVS sub is almost certainly much better than the AudioEngine sub, but I already have the AudioEngine sub. And I can’t live without the warmth a sub gives (I tried), but I am thinking about adding another sub (the SVS) to get rid of some bass nodes and null nodes that one sub always gives.
But which of option 1 and 2 will sound best do you think? The Dynaudio X14A is basically same as Dynaudio Xeo 4 but without the wireless part (if that helps).
I’ve not heard the DynAudios so can’t comment on SQ specifically. Bear in mind that there is only a single subwoofer out on the Kefs so you only get mono sub. Obviously using an RCA splitter means you could still use 2 subs which may help with bass management for your room but, even then, I’d recommend spending the money on a sub room calibration unit like the Dspeaker anti mode a stick with the one sub. I’ve tried the Kef extensively with and without a sub and, for me, the sub brings a degree of ambience that compliments the Kefs beautifully.
I have a very good room correction, used the new service at https://www.homeaudiofidelity.com which was excellent and a big step up from my previous one. Can’t have a sub (or 2) without room correction, that just makes everything muddled.
I had actually almost convinced myself to upgrade to KEF LS50, but now everything sounds so good I am not so sure anymore. Maybe a new DAC + good subwoofer would be a better upgrade for me.
There is another reason to stay with my current speaker: my wife wont notice some new small dac or replaced subwoofer, but she will notice the KEFs :slight_smile:
I would do some googling on DynAudios vs the Kef’s I’ve seen multiple people who have had both prefer the Kef’s including DarKo if you are familiar with him. A lot of people seem to have also gone from Devialet Phantoms to the Kef’s.
Mine have been noticed…and they are according to my wife too big and too bling for the room, and they need to be replaced with something half the size… Obviously this is not going to happen but i need to consider what concessions i can offer elsewhere. Perhaps if i pretend this conversation never happened they will start to blend in a bit more… We haven’t got to the cost bit yet… Perilous times!
I’m afraid my wife would get a 6 months “headache” if I buy the KEFs, but I would still have the KEFs after those 6 months so…
I am sure the KEFs sound better than my current Dynaudio, the cost almost twice as much after all. What I am considering is how much the gap will shrink if I upgrade to a better subwoofer and a better DAC which would be roughly the same cost as switching to the KEFs.
Hi Magnus
Maybe this is for another topic but can you tell about your experience with Home Audio Fidelity. Which sample track did you choose? Are there any options for tweeking the curve? Did you perform the mesurements the same way as in your REW guide?
I have nothing but good experience with Home Audio Fidelity, check this thread: https://community.roonlabs.com/t/roon-home-audio-fidelity-room-correction-convolution-filter-creation/29389/47. He needs sweep measurements though, so I used measurements according to Dirac (details in that thread).
Thanks. I will give it a read.
About KEF and Roon: can you control the volume from Roon, like a proper dac with volume control in the dac? Or do you have to use KEFs volume control?
I don’t know about the direct integration but using an Apple TV or SonicOrbiter, or Allo US Bridge all can have the volume controlled from Roon.
Apple TV is connected to TV by HDMI and TV to optical on the Kef’s.
SonicOrbiter and USBridge connected from ethernet to USB on the Kef’s.
My replacement Kef’s are on the UPS truck and I’m awaiting their return today :slight_smile:
If I buy them, I will connect them directly to the computer I run Roon on, preferably with WiFi or Ethernet-cable.
