Bekomme bei einigen Radiosendern folgende Meldung
Die Wiedergabe wurde unterbrochen weil ein Titel nicht geladen werden konnte
Bitte um Hilfe
Google Translation
I get the following message on some radio stations
Playback was interrupted because a title could not be loaded
Please help
Hello @Valentin_Bader , which radio stations are giving trouble? And which are good? I wonder if they are a certain type. Can you try
95bfm
(flac)
CJSW
(aac)
WRFG
(mp3)
And can you tell us a bit more about your setup please? In particular what core are you using?
Google translation
Hallo @Valentin_Bader , welche Radiosender machen Ärger? Und welche sind gut? Ich frage mich, ob sie ein bestimmter Typ sind. Kannst du es versuchen
95bfm
(flac)
CJSW
(aac)
WRFG
(mp3)
Und kannst du uns bitte etwas mehr über dein Setup erzählen? Welchen Kern verwendest du insbesondere?
Hallo Brian,
Betrifft SWR1 BW und SWR4 Rheinland-Pfalz
Setup
Netzwerkplayer ELAC
Server Innous Zen Mini mit Roon (bevorzugt)
Hi everybody,
same problems with swr 2. Seems to be a problem with mp3. SWR 2 works with128 bit
My configuration is
NAS Synology 218+
Fritzbox Cable
Audiodata DAC
Naim Uniti 2
Any helps? Thks in before
I’m away from home at the moment and so can’t properly test unfortunately, but I have managed to change some links on SWR1 and SWR2.
While I was active, I’ve changed the URLs on SWR3 and SWR4 too. I hope things are better now.
I’ll try and properly diagnose when I get back.
Es betrifft SWR4 Rheinland Pfalz und SWR1BW, Antenne Bayer Classic Rock
Antenne Bayern 70er Hits
Hitradio RTL 80er
Rock Antenne Classic Perlen
Dies sind die Sender bei denen die Meldung
Hello @Bernd_Wassmann , do the SWR stations work now? The problem was the original links were .m3u playlists which had some redirects, one of which caused Roon problems. The new links should be OK.
Do those other stations you mention cause problems too? They seem OK.
From Google
Hallo @Bernd_Wassmann, funktionieren die SWR-Sender jetzt? Das Problem war, dass die ursprünglichen Links .m3u-Wiedergabelisten waren, die einige Weiterleitungen hatten, von denen eine Roon-Probleme verursachte. Die neuen Links sollten in Ordnung sein.
Machen die anderen von Ihnen erwähnten Sender auch Probleme? Sie scheinen in Ordnung zu sein.
Thanks for this workaround. Sounds fine now. What I’m still missing on the stations are two:
Deutschlandfunk an Deutschlandfunk Kultur which are different. Is it possible to get them?
Thanks anyway for the first help.
Both stations are in the database. Easiest is to search for Deutschlandfunk
with the magnifying glass as there appears to be a bug with Roon not showing all the German regions.
from Google
Beide Stationen sind in der Datenbank. Am einfachsten ist es, mit der Lupe nach Deutschlandfunk
zu suchen, da es einen Bug zu geben scheint, bei dem Roon nicht alle deutschen Regionen anzeigt.
This topic was automatically closed after 15 hours. New replies are no longer allowed.
