Hi! I am having trouble with the Roon live Radio function: None of the stations is playing. It always says: „Die Wiedergabe wurde unterbrochen, weil ein Titel nicht geladen werden konnte.“ Using a NUC with Roon Rock.
Hello @Michael_Fried , have you installed the codecs?
Can you play a flac radio station - for instance Mother Earth Radio
See this KB article for help in installing codecs on a nuc.
Hello Brian,
thanks for your reply! The mentioned radio station is not shown when I am entering its name in the search. How do I find it?
Make sure you are using the correct search icon - easy to use the wrong one. You want the very top one
And do you have the codecs? The Rock UI will show missing codecs if there is something wrong.
Thank you for the help. Now it works! The missing codec was the problem. (Had wrongfully in mind that I already had installed it).
This topic was automatically closed after 2 days. New replies are no longer allowed.
