I just received my M11s and when connecting to my roon system I find the volume is low and the M11s volume control will not go beyond 60 some percent.
I see my roon limit set to 100 so what do I do?
TNX
TNX
On the M11 Pro, there are device-level volume controls in Settings > Global > Volume settings.
I’m referring to Android settings, not Roon settings. This is where “Max system volume” and “Max touch panel volume” can be set. Perhaps one of those settings is imposing the max limit of 60.
The global settings are maxed and the volume works GREAT on any other app.
That’s the only idea I have. Sorry.
