Lumin U2 mini "stuck" on firmware 15.0d
Hi, folks (and @wklie) - for some reason, my Lumin U2 mini is “stuck” on a very old firmware from 2022.
I’ve tried turning firmware updates on and off from the app, force quitting and re-updating, etc. And yet it still won’t offer any updates.
According to the Lumin support pages, there are (many) updates past this one that apply…did I do something wrong to get it to stop offering updates?
Thanks.
It would advisable to wait for Peter to respond but if you want you can do a full reset of the device & then try updating again….Details can be found on the lumin website :-
LUMIN Hardware Reset.
You know, I probably should have tried that…but I was trying to keep my Roon configuration intact. But, indeed, after a full reset it showed the firmware and I was able to update.
Thanks for the suggestion and fix - back to reconfiguring!
Glad to hear it’s resolved, sometimes the easy stuff works…:+1:t4:
@AceRimmer Kevin, this thread is resolved, please close it when you have a minute :pray:t2:
Closed as per your request sir!
