I’ve just set up a Mac Mini M1 as a Roon Core and its all working well although I’m not 100% sure I’ve set it up correctly as I don’t know what the final Audio Output is, I’ve got a USB cable running to a Nobsound Douk Audio U2 USB Converter to Toselink and then into my NAD C368 amplifier. Or that’s what I want to do…
Have I selected the right Audio on the Mac, it sounds good but I’m not 100% sure, I’ve attached a screenshot of the path.
Your output is MQA post first unfold, so 88.2khz at 24 bits. That should be processed losslessly by the USB to spdif converter. So that is what the DAC sees. However Roon is blind to anything beyond the USB interface so can’t show you in the signal path.
Hi…I think its working but I’m not sure what DSD is. I’ve got this set up and and a Bluesound Node 2i both going into my amp (NAD C368) via optical in and using the amps DAC, so I was expecting them to sound the same, but they don’t. The Mac Mini sounds like its outside and the BS inside, one doesn’t sound “better” than the other, just different. I’d like to get rid of the Node if the quality was the same in both…
