Mac Mini M1 Help
I do not think the same document applies if it is an old document. I am into software but not much into OS kernel and memory management. As a user, I noticed Mac OS ventura even uses more RAM or to be accurate utilizes more RAM. I noticed native apps run more efficient and faster and the memory shoots up depending on the physical memory available. A Lot of cashing in RAM takes place which improves performance.
I bought first a mac mini with 8GB for casual use and after a week I returned it for the 16GB. first time I notice more RAM is critical in the ARM M architecture. All as experienced user.
Windows behaves very different.
if you have some extra cash go with M1 or M2, much faster.
To give you a small perspective for fun. I once built a Windows PC for a total of $7K without the monitor to use for HQPlayer upsampling. (2 NVIDEA, 1080ti at that time, I9 18 cores with 32GB RAM …).
The M! MAC mini today for $600 is faster than the Windows PC not to sat much more reliable. Today I run Windows when I have to.
That has been the same way for a long time. Same behavior I have observed from my 2003 PowerBook Pro running on PowerPC G4 processor to the current 2018 MacBook Pro (intel based). I do not own the MacBook M1 for various reasons, the MacOS memory model may be improved but I cannot image that it is different radically.
You can have two cores. Switch back and forth at will.
:slight_smile: If it would be a movie you would smash them one into another and create a new core beast
Just on a curiosity, why replace the nucleus?
Thank you for the OpenCore reminder. I had forgotten all about that. I guess at some point I won’t have anything to lose. Might as well give it a try.
Enjoy. Yes with this setup it is fine. Try HQP and you will memory will not be sufficient to run DSD 128 or higher properly.
Also, I guess you should upgrade your Roon Server to run the native ARM version. Roon 2 should show Apple not Intel.
Not until 2.0 runs without requiring always on internet. I beta tested 2.0 so I understand but am not at all pleased with Roon’s new direction.
Ive been using the M1 Mac mini for over a year now with Roon Core. No issues at all.
Installing exFS WILL make it be like it was supported out of the box.
I know, like I wrote several times myself, but that’s not what was said in the post that I replied to
Not irrelevant because SMB’s pathname constraints, those of MacOS, and those of Linux are not identical, so exotic pathnames may lead to unexpected behavior with Roon.
