I have written a small app to control my NAD M33 from my Mac, I’m only using Roon for my streaming needs but I don’t want to use the BlueOS Controller to change settings on the NAD.
Perfect. Thank you. Now it works fine.
The M33 is connected by ethernet.
After the IP has been accepted i just had to restart the Mac to get the Dot and the M33 Name in the menubar. Bevor it has been missing. Maybe a hint for others installing this nice little program.
Also i can tell you it works fine with my M10v2. Its easy to change the IP when using the other amp
The Bluos API don’t have a standby function API, I don’t think there is a way to do than over the network. If anyone has an idea that should be simple and cost effective, I would look into it.
A small device that can send IR commands and be triggered via the LAN would OK to send the OFF command.
Works perfect now.
I added " „Application is agent (UIElement) “ in the info.plist and set the value to “Yes”. I don´t need the App-Icon in the Dock while running.
