ROCK on NUC 8i5 running 1159
Matrix Mini-i Pro 3 - latest firmware
Both connected to same router via ethernet.
Since update to 1159 the following status is observed:
Radio Stations will not play through the Pro 3 (mp3 or AAC streams).
Roon controller activates the Pro 3 then this happens:
First:
Roon controller indicates that the Pro 3 is playing.
Pro 3 display states “not playing”
No movement of time counter in roon controller
No Audio
Then, a cycle loop occurs:
Roon controller indicates that the stream is “stopped”
Pro 3 displays the Radio Station in the display and states “Streaming”
No movement of time counter on Pro 3 display
No Audio
After this the Pro 3 is essentially frozen and power off / on required.
Non of this happens if playing music files from local library or qobuz / tidal, all is fine.
MP3 from local library play fine.
Same result regardless of controller used:
Imac - v2 1159 early access
huawei mate 10 pro - v2 1149 early access
If I enable Imac optical out or use a topping d10b on USB with optical out to the Pro 3, then radio stations play fine out the Pro 3.
Enabling Pro 3 via Airplay also allows live radio to stream as normal.
Issue is specific to Roon Ready / RAAT on Pro 3
All other zones in the house play radio stations normally.
This includes a Matrix Element M.
Pro 3 is on latest firmware.
Anybody else with a Pro 3 able to reproduce this?
