Mcintosh C53 // Volume Setting
Hi, I am using my Roon through Macbook Air into Mcintosh C53 preamplifier and I am wondering what volume setup I need to have. Currently, default setting is device volume and it says volume is fixed but I am wondering whether “fixed volume” option is preferable to “device volume” setting. I don’t seem to understand the difference between the two setups as both claim to have fixed volume. Also, I did not understand anything from Roon’s definition of device volume and fixed volume option. You can see my current setup below
Thank you,
Are you using USB cable?
Sorry, my question is not related to your issue, I am currently weighing up a C53 purchase, your thoughts on your C53 please.
Regards Andrew
It’s a couple of years late but here’s my answere the C53 is one of the finest preamplifiers on the market. Now it’s the c55
