Just an FYI for other MS200 users. I have fitted an ifI power supply 12v 1.8 amp to my MS200 in my main system and it’s really singing nice.
The ifI has a straight mains adapter unlike Meridians standard L shape effort. You don’t need any of the adapters ifI supplies with the unit either.
£50 well spent I think.
Hello Chris,
Where did you buy the power supply from. I live in the UK.
Regards,
Simon
Hi, I bought it here. Very quick delivery. Be sure to specify the voltage you require.
Cheers. Chris
Thanks, You are a Star. Also thanks for your quick response considering the date of your first post.
Kind regards,
Simon Clifford-Smith
