Good morning
I’m building a music server with a SOTM sMB-Q370 motherboard + sCLK-EX 24 and 25 Mhz clock
I installed a core I5 9500 + 16 GB of DDR4 2600 MHZ
there is also a 500 GB NVME Firecuda 530 SSD for the operating system
there is a Jcat USB XE card which is supplied with 5 Volt 3 A externally with a linear power supply
I have a Hifi HDplex 400 combo, on which
I connected the 19 Volt 6 A power supply that I have on another server
but it does not start
while on the other server on which I have an MSI B550 motherboard + AMD Ryzen 5700 G processor, no problem
so for now I have connected a 400 W Pc power supply,
- the 24 pins of the motherboard
-the 8 Pins for the CPU
-the Sata on the clock
motherboard boots and shuts down ![]()
if I only connect the 24 Pins ATX and the SATA to the clock, it starts and stays on, then I connect the 8 Pins to the CPU and there I have access to the bios
Is it the lack of power?
I use Roon Server/Hqplayer embedded/Gentooplayer
thank you for your reply
Jean-Luc
